Posted by D7fever on July 05, 2013 at 18:39:51 from (72.79.239.29):
In Reply to: Farmall H backfires posted by Shop teacher 94 on July 05, 2013 at 15:01:17:
do you have an external resistor for the coil? If not it is probably the coil. Make sure that your ignition wires are not crossed. Do you have the correct point gap? Make sure that your rotor is not hitting the distributor cap. I have had this problem with some new parts. If all your ignition is ok, then try carburation . I changed my Champion plugs out for AC or AUTOLITE. Some people like the Champs, I do not.
Today's Featured Article - Fabrication (Who Me? Make it myself?) - by Chris Pratt. First of all, what are the reasons for not fabricatin your own parts? Most judgements on what should be purchased rather than fabricated stem from: Originality - If the tractor restoration is to be 100% original, it is likely that you should spend the time and money to locate the component in the used or New-old-stock market. Since this can be extremely difficult, you may want to fabricate the item or purchase a modern replacement temporarily, but eventually, you s
... [Read Article]
Latest Ad:
[More Ads]
