Re: Tuning up the Farmall 400
Posted by rustred on July 08, 2013 at 08:39:03 from (74.214.152.80):
In Reply to: Re: Tuning up the Farmall 400 posted by BBK on July 08, 2013 at 08:00:34:
also to add to the above advice , there is high and low idle adjustments on the governor once the linkage is adjusted. to get at this need to remove governor housing cover. a manual is helpful here.
