Re: Thought I had the H fixed.
Posted by mkirsch on July 10, 2013 at 13:29:40 from (64.80.110.74):
In Reply to: Thought I had the H fixed. posted by Shop teacher 94 on July 10, 2013 at 12:44:17:
What kind of wires did you replace them with?
Are you sure you got the firing order right?
Have you checked for spark at the plugs with the new wires?
Does it start if you switch back to the old wires?
If you do get it running and it runs ok, use it and then when it starts acting up again, give it some choke.
If the choke straightens it out then it's a fuel problem.
If the choke kills it it's an ignition problem, most likely.
I don't know a lot about magnetos but it could be that the coil is breaking down, causing the spark to become erratic.
