Posted by Shop teacher 94 on July 10, 2013 at 12:44:17 from (50.33.62.191):
Reset the points on the H today. started up and ran great...for 5 minute...then died. Restarted it up and it ran for 20 and died.
Checked the fuel flow...all is good. Cleaned the screen on the fuel intake... set the mixture to run a little leaner..
Ran great for an hour at mid idle...
Took it out and started pushing a little dirt around to give it a bit of a work out. First ten minutes were great. Did what i wanted too...then it started backfiring again and lost a lot of power...
With it still running, i adjusted the magneto to see if timing was off...where ever I moved it just screwed it up worse. so I put it back where it was. Noticed a spark out of the lead wire from the coil to the cap...switched out the wires and now I cant get it to start again.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
