Posted by Dee A. Gifford on July 10, 2013 at 16:48:10 from (69.171.121.45):
Several teeth missing. Tractor is split in half at the transmission. Removed the covers for the front upper and lower bearings. Now, I am trying to figure out how to remove the upper and lower gears from the shaft and the transmission case. The upper shaft is very loose but there is no way that I can remove it without removing the pinion gear going to the ring gear of the differential. The lower shaft is loose, and it extends back to the PTO shaft. How do I separate the bottom shaft to remove the bottom gears and allow (maybe)the removal of the gears on the top shaft.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
