Re: Farmall 706 PTO problem
Posted by DeltaRed on July 10, 2013 at 17:49:24 from (97.118.25.134):
In Reply to: Farmall 706 PTO problem posted by Ardie on July 10, 2013 at 17:36:40:
Is the hydralic oil level up?the pto will quit before the steering if the fluid is low,especially if the front is going down hill.I once had the little engageing plunger snap inside the pto unit.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
