Farmall 706 PTO problem
Posted by Ardie on July 10, 2013 at 17:36:40 from (174.71.94.241):
I have a 1963 706 Diesel. I was mowing with it and the PTO has always worked good. I engaged the PTO and nothing. The lever to engage it feels and works like it should but the PTO does not engage, you can manually turn the PTO but does not engage. Thanks for your help!!
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
