if you can manually turn the shaft, the pto brake is probably shot.
has it been run on pto work when low on oil? good way to burn out pto clutches.
there is a tiny pin that holds the 2 parts of the pto control valve spool together that brakes sometimes. then you have nothing. remove plug at lower left of pto housing (have to remove hitch cradle first), oil will come out slowly. if the bottom part of the valve falls out, that's your problem.
make sure you set the correct lock-up pressure when you get all done. 600 psi gauge on the test port.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
