Re: Thought I had the H fixed.
Posted by gene bender on July 11, 2013 at 10:16:08 from (67.55.227.12):
In Reply to: Re: Thought I had the H fixed. posted by teddy52food on July 10, 2013 at 19:49:38:
The mag on the H cannot be advanced by rotating on the tractor as the armature is locked to the tming gear and all you do is rotate the field does not change the points setting you must not be familiar with the H-4 MAG
