Re: Thought I had the H fixed.
Posted by Owen Aaland on July 11, 2013 at 15:06:58 from (216.47.35.84):
In Reply to: Thought I had the H fixed. posted by gene bender on July 11, 2013 at 10:16:08:
Timing of a magneto is affected the same way as timing of a distributor. In both cases the rotating member does not change in relation to the timing gears but, in both cases, the points themselves are rotated which does affect when the spark occurs.
