Did the noise sound like its at the rear of the tractor? Hard to say without being there. If it has the seasonal disconnect check that the dogs are not jumping apart. It springs the shift linkage when they do. Also at the oil level check plug at the front of the center housing. You can look through the hole with a light and see the teeth on the lower PTO drive gear. If the upper gear lost teeth you may see signs of damage on the lower one also. Not sure if to much oil would sling to have a helper see if the lower gear stops turning through the hole when the PTO stops. That could mean the PP, shaft splines or upper gear stripped.
Rear unit has plenty of parts to cause a problem also. May remove the engine spark plugs. Place trans in neutral. Engage the pto and by turning the pto shaft with whatever and the engine also, find or listen for the problem location.
Didn't see CharlieU post until after I posted. That's a good idea to look in the clutch compartment for metal cuttings. Shaft is hard to see in there.
This post was edited by D Slater at 10:54:23 07/11/13 2 times.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
