Re: Re: Super C oil type?
Posted by Bob R on November 25, 2000 at 06:37:34 from (209.198.80.158):
In Reply to: Re: Super C oil type? posted by The Red on November 25, 2000 at 05:41:47:
Am curious where you can get non-detergent oil .
Its a pink elepahant for availability ? Most likely the tractors been oiled up with detergent , correct ?
The viscosity depends on the temperature your operating in . I will maintain 30 weight , My H has a heater for the block . So no cold starts for it . Case has lighter weight oils , if you go that route . There detergent as far as I know .
The case oil I use is low ash and has a lot of detergent in it .
hope to have helped
Post A Followup
: Re: Re: Re: Super C oil type?
