Broke the idle tube on Cub carb
Posted by anvilheadtexas on July 12, 2013 at 21:13:58 from (99.117.216.44):
Well.... I went ahead and let my big hands get int he way and broke the idle tube off right where it goes into the top half of the carb (Cub). Is here a remedy? Luckily I received two carbs when I bought the tractor.....should I just use the half of the other one? Or can I replace the idel tube on broke one.
I noted that the two halves have a bit of a gap (without the gasket mounted). It seemed to be there when matching up either top (broken idel and none broken idle). IS this common. Does the gasket solve the gap problem.
