Re: Farmall C charging system will not work
Posted by gene bender on July 12, 2013 at 23:17:14 from (67.55.227.12):
In Reply to: Farmall C charging system will not work posted by Nick M. on July 12, 2013 at 21:01:51:
you need to probaply polorize the gen making sure your battery is hooked to positive ground cause your reg is made for pos ground. Thats figuring you have the correct regulator. After all the years hard to tell just what you have by now. But when new the system did have a positive ground system. Do you know what the Delco Remy gen # is on the tag. That would be a good place to start when figuring out your system.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
