Posted by Bohn Super C on July 14, 2013 at 11:16:28 from (174.124.162.235):
I have a 1954 Super C that I bought about three years ago. The problem that I have is that when I am mowing my four acre property, the engine speed keeps changing. I will be mowing along and the engine will rev up and I will pull back on the throttle lever a few notches and slow the rpm down, and about 15 or 20 seconds later the engine will run too slow. So I move the throttle lever up again a few notches to the rpm that I want, and about 15 or 20 seconds later the engine revs up again, and back and forth I go all day. I know I have a carb problem because I have to have the choke closed a little for it to run without sputtering. It has a CARTER UT 0-653 carburetor. Should I buy a carb kit for this or would I be better off buying a ZENITH carb? Also, someone has changed the governor housing off a 240 to my Super C, so I'm not sure that the linkage is adjusted right. I think the reason for the 240 governor housing is so they can add oil to the tractor because they cut down the exhaust tube as well as the rocker cover and air cleaner tubes. I have two manuals and one said to insert the pin when the holes line up and the other said to extend the rod one full turn, then insert the pin. Which one is right? I will try to upoad Photo's.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
