Re: International 2400/464 Fuel problems
Posted by jimb2 on July 14, 2013 at 15:19:02 from (99.241.76.141):
In Reply to: International 2400/464 Fuel problems posted by bcwhalo4 on July 14, 2013 at 13:11:00:
Hi, I assume the 2400B is a Diesel. Most common
problem on that style of tractor is junk in the
bottom of the fuel tank. With a clean bucket under
the fuel line take the fuel line off at the input
to the primary fuel filter and let it run into the
bucket. The fuel should flow the full of the fuel
line pipe. If it does not or gradually slows down
then junk is blocking the fuel outlet in the
bottom of the tank. If you have good flow into
fuel filters the next place is to check at input
to injection pump. Depending if your tractor has
the 1 or 2 fuel filter system, the fuel line comes
around the front of the engine and before going
into injection pump the line changes from steel to
flexible and sometimes the inside of the flexible
part will collapse.
If you have junk in the tank you must drain both
sides and remove the outlet valve and clean. My
brother's 684 had the remnants of a lady bug that
would blog the outlet screen.
jimb
