I have the 2 filter system, but I bypassed the secondary filter right before the injector pump. (I think it was sucking air through the o-ring on the glass bowl). Even with it bypassed, it will only run well for about 5-10 min before losing power. The weird thing is that it will idle just fine, just won't do anything more. After that, if I let it sit for about 30 minutes, it will start up just fine and then do it again. I will have to check the fuel tank like you said, because it makes since that it could be starving for fuel.
There is also a small leak on the injector pump. Just a small drip. But im not sure that is the problem because I used it for a long time with the small drip like that. Thank you for the feedback and I will post again after I am able to try the tank cleaning.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
