OK thanks. Just my luck. lol According to the internet source i found, the SN was supposed to be on the bell housing on the right side of the engine. I did find a flat spot there that has absolutely nothing on it, i used a wire brush in my air tool to clean that spot and nothing. I then found another website that showed a pic of that spot and it looks like there should have been a data plate glued to that flat spot, which in my case is gone. So back to the drawing board. I will pull the pan today and look for clues there. I pulled the head already and found nothing except there is a hairline CRACK in the block between piston 1 and 2 and I think that is how the water got in the oil pan.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
