Re: farmall c float
Posted by old on July 17, 2013 at 13:12:59 from (209.86.226.34):
In Reply to: Re: farmall c float posted by indiana george on July 17, 2013 at 11:42:43:
Pull the air tube off the carb and hold your hand over the air intake of the carb and try to start it. You should both feel suction and also get gas on your hand shoot it may even try to start. If you do not get a good suction and or gas on your hand then you have either a compression problem or a carb passage still clogged up
