Re: Re: Re: Re: Re: Re: Re: Re: FARMALL 130 12 VOLT CONVERSION COMPLETE
Posted by Jeremy on November 25, 2000 at 19:15:12 from (209.240.220.175):
In Reply to: Re: Re: Re: Re: Re: Re: Re: FARMALL 130 12 VOLT CONVERSION COMPLETE posted by Bob R on November 25, 2000 at 19:02:47:
Well I think the rotor button is ok. Just a grayish/white film around it. It may have been there from another time. Since the points are not black and are still shinny do I need new ones, or should I just try the resistor first. After I tried all this I read the discussion you and Bob M had on the resistors. Probably should've read it sooner. Thanks for all of your advice. This discussion board is packed with guys who know what they're doin'.
Thanks again,
Jeremy
Post A Followup
: Re: Re: Re: Re: Re: Re: Re: Re: Re: FARMALL 130 12 VOLT CONVERSION COMPLETE
