Re: Re: Re: Re: Re: Re: Re: FARMALL 130 12 VOLT CONVERSION COMPLETE
Posted by Bob R on November 25, 2000 at 19:02:47 from (209.198.116.162):
In Reply to: Re: Re: Re: Re: Re: Re: FARMALL 130 12 VOLT CONVERSION COMPLETE posted by Jeremy again on November 25, 2000 at 17:49:21:
The resistor is large . You will want a resistor or another type coil . Napa should have either .
Wire the resistor between power wire and coil . You can take a resistor off an old car too .
So the rotor took a beating , how old was it ?
Good luck
your on your way to a good thing
The resistor is called a ballast resistor , Gm mounted them on the firewall near the wiper motor . About 3/4" X 3/4" X 3" long white thing .
Old car sources like ol 55 or danchuck mfg and others will have new ones . Or junk yard with old cars . This is 30 year old suff or older .
Post A Followup
: Re: Re: Re: Re: Re: Re: Re: Re: FARMALL 130 12 VOLT CONVERSION COMPLETE
