Re: tripple baffle gas cap
Posted by Janicholson on July 19, 2013 at 05:59:14 from (199.17.6.60):
In Reply to: tripple baffle gas cap posted by farmall plowboy on July 19, 2013 at 05:33:02:
THe original cap with vent and gasket was typical for the times. It had the following issues:
When the tractor was fillednear full, and driven, the fuel would splash against the cap and erupt out of the vent.
The ability of the cap to conform to the (often bent) tank neck was marginal, allowing more leaking.
The cap had no ability to limit leakage in a tractor accident.
Many law suits were filed and a court settelment was reached requiring the replacement of all IH/Farmall fuel caps of the non baffeled style with the far more protective taller cap.
They are free, they work, and can be painted to match.
Many purists use the original cap at static shows, but revert to the baffeled cap when running the tractor.
If you were to have an accident, or your tractor was in an incident in which there was a fire, you might be considered an accessory to resulting fire if you use the old style short cap.
Jim
