Re: reassembling the upper front bolster on an H
Posted by Bob M on July 20, 2013 at 08:44:22 from (69.207.86.200):
In Reply to: reassembling the upper front bolster on an H posted by Brad in WI on July 19, 2013 at 19:20:06:
I made an insertion tool from a short piece of wood dowel. Turn the dowel OD to just a bit smaller than the seal OD, then turn 1/4" off one end to match the seal ID.
Set the seal on the end of the dowel with the elastomer side facing UP and lightly tap it into place.
