reassembling the upper front bolster on an H
Posted by Brad in WI on July 19, 2013 at 19:20:06 from (198.190.116.86):
I completely disassembled the upper front bolster on my 1941 H a few months back and now it is time to put it all back together. Is there anything that I have to watch for when I do put everything back where it belongs. I do have a new thrust bearing as mine was rusted tight and a new seal to install that goes under the steering gear box. I have heard that there is a trick or something to putting in that seal as to not wreck it upon installation. Brad
