To clamp the assembly in place on the shaft, use bolts inserted through the unthreaded holes in the adapter/hub and thread them into the pulley, and snug them down evenly, moving from one to the next "til the adapter/hub is drawn tight into the pulley and clamps firmly on the shaft.
Bolts can be screwed into the 3 holes in the adapter/hub that ARE threaded to SEPARATE the pulley and adapter for removal, if ever required.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
