I looked at thnr pulley and adapter again and it has 6 bolts in the adapter. Three are threaded into the pulley and three are threaded into the adapter. Which ones do you tighten to secure the adapter to the shaft? The adapter is stamped Browning p 11-1/8 6 spline
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
