I put one of these on a Super A about 20 years ago and have since sold the mower to my SIL. So, from memory which isn't that good, you use three bolts to clamp the 2 piece pulley to the shaft. I think its bolts thru the pulley into the threaded holes in the hub but it may be the other way around. The threaded holes in the other piece are used to force the pieces apart when you want to take the pulley off the shaft. I'm going over to SIL tonight and I'll take a look at it.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
