Re: Sad Day for the Super M's - Grandpa nearly showed them up
Posted by jd50A on July 21, 2013 at 16:39:38 from (76.240.47.39):
In Reply to: Sad Day for the Super M's - Grandpa nearly showed them up posted by Tom Fleming on July 21, 2013 at 03:42:19:
Tom, did they pull all weights both days ? I used to pull there but Tuffy said it was to much work pulling all wt. classes both days. Only let you pull once all weekend. Sounds like you "DID GOOD"
