Re: Farmall C - Leaking gear oil
Posted by Rick Remmert on July 21, 2013 at 17:17:53 from (68.103.4.23):
In Reply to: Farmall C - Leaking gear oil posted by C. Amick on July 21, 2013 at 16:21:10:
Yes, there is a seal on each end to the shaft. It is just a lip type. If you can't find the number or no one on here answers back with it, let me know I can get it for you tomorrow. You will have to drain a gallon or so out of the rear end as you will have oil running out of the shaft holes when you remove the shaft. Before you pull the shaft, remove the woodruff keys as it will make removal easier.
