Re: Farmall C - Leaking gear oil
Posted by C. Amick on July 22, 2013 at 09:33:09 from (173.224.156.121):
In Reply to: Re: Farmall C - Leaking gear oil posted by Rick Remmert on July 21, 2013 at 17:17:53:
I assume the replacement proceedure is: remove the shaft, remove the old seals, re-install the shaft and then slide the new seals down the shaft? If you can give me the seal part number, I would appreciate it. I still don"t see it shown on the parts diagram that I downloaded from Case/IH.
