1486 hyd psi and releif valve
Posted by Larry B. 1486 on July 21, 2013 at 19:14:21 from (98.19.163.140):
I have had some recent post on this problem not having psi on my aux outlets. My gauge shows 2000 psi cold , 1900 psi hot. Most comments say relief valve. I went Saturday and bought a new relief valve. They sold three different psi, 2100, 2250 and 2500. I bought the 2500 psi valve. I have not yet installed the new valve yet. My question is, do the pumps put out that much pressure? I always though they only maxed out 2100 psi or did the 86 series have a higher pressure pump? If I install this valve and my pump is good will I have 2500 psi also? Can you buy higher psi pumps also for the 1486? Thanks Larry
