Re: touch Control Rebuild kit?
Posted by chad from michigan on July 22, 2013 at 03:47:09 from (70.39.231.100):
In Reply to: Re: touch Control Rebuild kit? posted by chad from michigan on July 22, 2013 at 03:44:31:
third party image
here is the hyd manifold which one are you suppose to use to test pressure?
far left post is where the loader spool hooks to.
the middle one is 1/8 npt and I hooked a guage there and didn't get anything. The far right port I can not get out but if need be I can take it off and drill out and use an easy out to get the plug out. Is the far right port the high pressure side?
