Re: FARMALL 130 12 VOLT CONVERSION COMPLETE
Posted by Jamie on November 26, 2000 at 08:49:45 from (24.218.208.40):
In Reply to: FARMALL 130 12 VOLT CONVERSION COMPLETE posted by Jeremy on November 24, 2000 at 17:44:20:
Jeremy,
If you are converting from positive ground to negative ground at the same time as you go to 12V, don't forget to switch the leads on the coil. Otherwise, you will cause the coil to overheat and ruin it.
Post A Followup
: Re: Re: FARMALL 130 12 VOLT CONVERSION COMPLETE
