Re: Cub parts - did I get the right ones...
Posted by jrmartin1964 on July 27, 2013 at 18:27:23 from (69.35.176.251):
In Reply to: Cub parts - did I get the right ones... posted by anvilheadtexas on July 27, 2013 at 17:46:58:
The tune up kit is right, even without specifying on the package it is for a Cub. That one kit fits just about every 4-cylinder gas-powered tractor built by IH that used the IH distributor. In fact, except for the rotor, the Cub's J-4 magneto uses the very same parts.
Does your Cub start by pulling a rod that's attached by a lever to the starting switch? or does it start by turning a switch/pushing a button that's connected to a solenoid that is in turn connected to a threaded lug on the starter? If it's the first one, then the new switch is the correct one. If it's the second type, then no, and it's not what you need at all.
Jim
This post was edited by jrmartin1964 at 18:38:08 07/27/13.
Today's Featured Article - The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea ... [Read Article]
