Re: replacing rings on f20 and cant get piston back in
Posted by Chummymatt on July 28, 2013 at 07:56:04 from (70.194.133.2):
In Reply to: replacing rings on f20 and cant get piston back in posted by chummymatt on July 26, 2013 at 19:33:04:
I got the rings on and in f 20 thanks for all the help it just takes alittle time and work with the compressor.
Now it's time for the mag what to do, what to do take it to a guy to rebuild, or try and have the guy come to make place to work on it? I. didn't want to take it off if I don't have too. And then comes the carb, I have a kit to rebuild it but, I took the top off and it look really good on the inside, and found out its a kerosene carb mostly don't have the right kit. The main seals I want to replace them, what r they made of? I got a complete engine gasket kit and it has two different size felt gaskets in it r they for the crank seals. Thanks much for the help chummy
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
