Re: replacing rings on f20 and cant get piston back in
Posted by 36F30 on July 28, 2013 at 10:53:26 from (97.125.197.225):
In Reply to: replacing rings on f20 and cant get piston back in posted by Chummymatt on July 28, 2013 at 07:56:04:
If you got a Kit for a K5 carb, you have the right kit. There is no other carb for a F20 or a "gas" carb they were all Kerosene carbs and work with either fuel.
A bit of advice, the F series hand crank tractors start easy if everything is working correctly. Carb, mag, compression. If one of the systems is off they can be a bear and downright dangerous to your health. Soak and clean the carb with meticulous care even if it looks clean. Send the mag to someone who works on MAGS, someone like Nebraska Kirk. Once you have a clean fuel system and carb, A hot mag timed correctly to the engine, and good intake with compression and tight valves..... It will start easy and run well, so do it right the first time.
The crank seals are felt, the front one is easy, its the smaller one, the rear seal is the bigger one and you have to pull the flywheel to change it. Even with new seals, most F series like to "mark" their territories.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
