Loren, I have 756, 856 and 1456 all with two valves and original steel tubing . I have attached a picture showing routing of tubing from valves to the "blocks". My tractors do not have the steel tubing that runs forward to provide hydraulics for front mounted equipment such as front mounted cultivator. 56 series tractors used steel lines from the rear blocks and routed them under the platform, with couplers mounted under both front corners of the platform . 06 series tractors with front hydraulic couplers had lines that attached to the valves with stacked ( one on top of the other) banjo fittings and routed them under the center of the platform to the steering support pedestal to couplers on both sides of the pedestal. Hope this helps. I have more pictures that I can send directly to your e-mail address, (which I believe that I have from corresponding with you at other times), if you want to see more of them . E-mail if you need to. Weldon K
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
