You say the load screw does absolutely nothing. Do you mean you can screw it all the way in and it will not kill engine or keep screwing it out and notice no change. A lot of the packings behind nut are too long and needle will bottom in nut before end of needle gets to the main jet inside carb. Another thing, there are different lengths needles used with a different taper on needle and jet also for power improvement packages like fire craters. Then the main jet is calibrated for full load so screwing it out ten turns will not give more fuel than the size of jet, only limit amount delivered for light loads. On a side note, first 450 gas I did a valve job on had a burned intake valve with low hours from needle screwed in to save that extra fuel but he used it that way on all loads. IH did give him a free valve job though.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
