Re: Super M carb adjustment(double checking here!!! :(
Posted by CNKS on July 29, 2013 at 13:58:14 from (216.144.104.128):
In Reply to: Re: Super M carb adjustment(double checking here!!! :( posted by pete 23 on July 29, 2013 at 11:09:52:
Yes, the needle on my 460 carb never gets inside the jet. The carb on my Super H can be adjusted just like the H carb-turn in until rough, out until smooth-I did that after cleaning the carb and found that it had power to move the tractor, but that was all. I then read the Operators manual and found that max power was 5 turns out. I haven't driven the SH with much of a load. I have experimented with the 460 and a bush hog, it runs better 5 turns out, maybe 4 if I never leave 2nd. 3rd is a little fast for mowing so I use 4th TA, faster than 2nd, slower than 3rd. I guess the answer is don't mix parts even though the carbs look the same.
