Re: M hydraulic problems could use some experience here
Posted by D Slater on July 29, 2013 at 12:23:14 from (184.14.183.16):
In Reply to: Re: M hydraulic problems could use some experience here posted by NolanJae on July 29, 2013 at 11:03:17:
Think anymore most experts don't recommend anything more restrictive than a screen or screen element on a suction line in a system like yours.
Also how high is the suction line going into the reservoir, in the picture I can't tell. Filter in the return line usually goes in the line from the control valve back to reservoir. No place to do that with the IH valve mounted like yours.
If the reservoir is clean it wouldn't hurt to bypass the filter and give it a try. Unless you can get the hydraulics moving from stop to stop its hard to work the air out. If you get most of the air out it probably wouldn't hurt to close the bleed valve on the fill cap.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
