Re: M&W hand clutch
Posted by mkirsch on July 30, 2013 at 05:56:04 from (64.80.110.74):
In Reply to: M&W hand clutch posted by mkirsch on July 29, 2013 at 05:27:44:
Nope, no tabs catching. I took a screwdriver and pushed them all back.
The cover was loose, and the lever was wobbling.
Between banging on the nut, bending the hold-down clips to hold the cover on tight, and shimming up the lever, the clutch now works!
Before, I could pull it with a 3-bottom plow sunk in sod, and it would keep going. Now it stops with a tap on the brakes.
It should "pop" in and out, right?
