Re: M&W hand clutch
Posted by kevinj54 on July 30, 2013 at 06:00:32 from (162.17.149.81):
In Reply to: M&W hand clutch posted by mkirsch on July 30, 2013 at 05:56:04:
The cover is supposed to float a bit and not be tight on the shaft end.
Yes it should pop out and the tractor should stop.
You still need to pull the clutch pack, clean and inspect, as something is not right in there.
