Re: M lift-all reservior----motor oil or Hy-tran??
Posted by Ellis Kinney on July 30, 2013 at 17:03:02 from (74.136.122.115):
In Reply to: M lift-all reservior----motor oil or Hy-tran?? posted by NolanJae on July 30, 2013 at 07:39:40:
If you have a standard M with the pump in the belly you need 30wt non detergent motor oil. I have tried hy-tran, and the pump will lift, but it whines and is slow. Change to 30wt and it lifts better with no whine. If you have a Super MTA it uses IH touch control fluid, which is Hi-tran. Ellis
