Re: M lift-all reservior----motor oil or Hy-tran??
Posted by sflem849 on July 30, 2013 at 19:05:04 from (69.197.84.39):
In Reply to: M lift-all reservior----motor oil or Hy-tran?? posted by Ellis Kinney on July 30, 2013 at 17:03:02:
The only way it would lift better is if the pump is worn out and not in spec. If the pump is good it will lift the same with hytran, 30wt, baby oil, or water. All you need is a minimally compressible liquid. A hydraulic system doesn't care what the fluid is.
