Farmall 656 Overheating Problem
Posted by John Athey on August 01, 2013 at 08:53:09 from (216.99.184.50):
Need some advice....my 656 is overheating...
I have put a new waterpump on it and a new thermostat. Radiator is new, and has new coolant in it. What is next?
How do I figure this out......there is no water in the oil.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
