from what you have done, first thing that comes to mind is thermostat. New does not necessarily mean good, especially if imported. I would remove thermostat and test by putting in a pot of water, then heating water to see if it opens. A simple candy thermometer will tell at what temp. Another test is to run tractor without thermometer and see what happens. Good luck.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
