Re: SM Carb Help Please
Posted by Bob M on August 04, 2013 at 07:02:52 from (69.207.86.200):
In Reply to: SM Carb Help Please posted by Pete_5959 on August 04, 2013 at 05:55:04:
Pete - Good chance it's a governor to carb linkage issue. A couple things to try:
Loosen (don't remove) the two screws that clamp the throttle shaft tube to the governor riser. Now have an assistant pull upward on the tube while you retighten both screws.
If that doesn't help, adjust the carb shaft linkage:
- Remove the cover at the top of the governor riser.
- Inside the riser remove the cotter from the pivot pin and remove the pin.
- Set the throttle handle wide open.
- Now turn the carb throttle shaft as far clockwise as it will go, lift the governor connecting rod as far as it will go and try to re-insert the pivot pin.
- If the pin does not slide in easily, loosen the locknut on the connecting rod block and adjust it up or down as required until the pin slides in.
- Finally tighten the locknut, replace the cotter pin and the riser cover.
