Posted by Pete_5959 on August 04, 2013 at 05:55:04 from (70.63.206.198):
I am having some difficulty in setting the low RPM to 350-400. I initilly set load screw at 3 turns out, air adj and idle screw per service manual. I am using dwell/tack and cannot get the idle rpm below 650 without adjusting load screw to where the engine is not running smoothly. At 3 turns out starts easily but if I turn in 1/2 to 3/4 of turn engine smooths right out and rpm"s increase about 400. The idle screww is fully backed out. Could the governor being out of adjustment cause this? Thanks for any advice.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
