Re: SM Carb Help Please
Posted by CNKS on August 04, 2013 at 08:15:08 from (216.144.104.128):
In Reply to: SM Carb Help Please posted by Pete_5959 on August 04, 2013 at 05:55:04:
I think your carb needs cleaning, the idle mixture seems to be the first indication. And the load on a Super H/Super M carb up is set at 5 turns out for max power but can be turned in for lighter loads. I have never tried it, but I doubt if it will pull anything but its own weight at 3 turns out. It is a SM carb if the choke lever is on the inside, If on the outside it is an M carb, and except for the idle adjustment forget what I said.
