F-20 Runs Rough
Posted by Lou Becker on August 04, 2013 at 15:21:10 from (208.123.182.150):
I have a 1938 Farmall F-20. I have taken the carburetor completely apart, soaked it, cleaned it again with carb cleaner, blown it out, checked the float level, replaced a cracked tube which goes down into the bowl, and put it back together and it still runs rough. When I turn the two adjustment screws(Idle & main jet) in and out, they do little if anything (same as before). The fuel bowl is clean, and I recently placed an in line filter between the bowl and carb. Also, years ago, this engine had the pistons replaced with the 1/4 oversize aluminum ones, and had the power carb kit installed. It also has a Wico Conversion Distributor installed (my dad installed this after it kicked and broke his wrist). Any idea why the engine still runs rough after doing the things I listed above? Could it be a spark plug issue?
thanks,
Lou
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
